Creating soffits
How do you create a soffit & fascia as a unified element. We have been using walls for the fascia and slabs for the soffit but they don't join like walls so we are getting additinal lines in either the elevations or the plan views.
13 REPLIES 13
TomWaltz
I'm using a profiled beam to make the soffit and fascia. I like the beam tool over the wall because you can slope it.
Tom Waltz
Steve Jepson
I use roofs for soffits sometimes.
I like being able to Ctrl click the edges for quick joints.
This is for interior soffit & fascias for commercial projects by the way. I amnot sure how you would use a roof for this. Also, I'm not familiar with the profiled beam. I opened the beam tool but I couldn't see how that could be sued to create and interior soffit & fascia. We are on Acad 9 so maybe this is not available to us.
Steve Jepson
I was thinking of soffited eaves. You can give it a slope of 0, or give it a pitch on the gable ends.
Do you not like to use the Profiler Tool for making soffit, facia, trim, all at one time?
Aussie John
Sounding like a broken CD but i agree roof for soffits but if they are sloping the 2d line position is incorrect if the roof has any thickness and the edge not vertical (eg at a mitre)
Cheers John
[/size]
I confer with Tom. Complex profiles are the way to go unless you are only dealing with a single element. Using the slab or roof tool has its benefits in that elevations can be automatically tagged using the level dimension tool with gravity on. You might search either the archives or the manual for complex profiles to see how these work. Complex profiles were introduced in 10 and I find my self using them all the time. Fast to create and edit.
With profiled beams (and walls of course) you can use the intersect tool. Even easier than ctrl clicking roofs. (I assume you are talking about joining soffits at the corners of hipped roofs.)
TomWaltz
I thought he meant at peaks, like at gables
Tom Waltz
Steve Jepson
yes. I was talking about just a single element. The soffit. Not all of the other parts. Roofs clean up well with walls(fascia) Fit to Roof or SEO.
Like everything else, it depends on if you are modeling for a materials list, for Rendering model only, 2d results only in working drawings, ect...
That's why there is never only one way to skin the cat.
