Curtain wall - How to create mitered corner panel
StefanV_BCP
Hello every one,
As sa topic tittle sugest, I am in need for solution how to create mitered corner panel using curtain wall tool, like we can do with windows tool.
Stefan
Stefan Veselinović
BIM Manager for Bureau Cube Partners, Serbia
WISH HUB: https://community.graphisoft.com/t5/Wishes/WISH-hub/td-p/393063
Ricardo Lopez
Hi @StefanV_BCP
I am not sure if you are asking exactly for this, but you are able to change profile intersection priorities as seen on this Community Article: Curtain Wall Tool - Intersection Priorities
If all profiles have the same intersection priority they will have mitered corners, but I guess joint will not be displayed.
Regards.
M. Arch. Ricardo López
AC17-28 SPA+INT | Windows 11 | MSI CreatorPro M16 HX C14VJG, 64GB, Nvidia Quadro RTX 2000 Ada Generation
StefanV_BCP
What I am asking is, how to create a mitered glass panel with CW tool. I have a strategy that I deploy but I would like to hear from fellow users about how are they dealing with this, specific situation.
Stefan
Stefan Veselinović
Hi @StefanV_BCP
You could edit the corner frame and make it invisible.
If this is not what you need, please send a sample picture.
Regards.
