rob2218
Curved Walls (curved edge not showing in elevation?)
I have quite a few curved walls in this model.
I've placed an "out of the box" exterior elevation and the "edge" of the curved wall is NOT showing....what gives folks?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
17 Replies 17
I will report this issue to Graphisoft.
Seems to be caused when the Window is placed so its edge is at the exact point where the curved and straight wall segments meet.
Rob, as a workaround you can try to move all your Windows in the curved Wall just a little tiny bit. The move should be so little that dimensioning does not even show it because of rounding. That way the line may appear.
rob2218
thank you Lasz for your suggestion.
I have indeed tried doing just that and the will still does not show its edge.
I've even tried to "remove" all the windows and still, no edge showing.
I just can't figure it out.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Hm, that's strange because I tried the same thing in my ArchiCAD copy and it worked and the line has now appeared.
If you remove the Window from the Wall, does the line appear? Just to establish that the Window is causing the line disappearance.
rob2218
I've tried it with two "simple" (basic) walls.
put them 90 degrees to each other....use the "fillet command" with a 5'-0" radius lets say...hit "enter" and the two walls will fillet themselves with a curved corner, then I look at them in elevation and no line to represent the curved corner...dunno.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Could you save this file and send it to your local reseller guy of GS USA or whoever provides you with support. This may be file-specific. I am sure the guys at GS HQ would be interested in looking at it.
rob2218
Most certainly will.
the file is "not" that large so I'll send it to my local GS reps.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Katalin Borszeki
We have investigated this issue and recorded the bug! It is planned to be fixed in the next ArchiCAD version, ArchiCAD 19!! Tx for the input!!
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
rob2218
Chalk up another bug to me! That makes 2......well, at least now I can sleep at night knowing I'm not going insane.
i>u
Edgewater, FL!
SOFTWARE VERSION:
