2005-03-03 01:33 AM - last edited on 2023-05-23 03:37 PM by Rubia Torres
2005-03-03 02:01 AM
2005-03-03 02:44 AM
David wrote:Yes, do the curved roof portion with the roof tool...unfortunately, I need to use the "GDL" word regarding the fascia. Why don't you try some graphical GDL? After you model the roof do a quick 3d view of the elevation...copy the line work of the area where the curving swoop is and use the line work as a template...Paste the linework on plan and model the trim geometry with slabs and/or walls ... save it out as a "static" object to apply to the model.
... I assume I would model the roof with the curved roof tool but the fascia method escapes me.
2005-03-03 04:05 AM
2005-03-03 04:15 AM
gpowless wrote:this is basically the same process as stated in my previous post...its what I was referring to as "graphical GDL"
Personally I wouldn't get so complicated as to create GDL to solve the problem.
Rather, I would call up the elevation, create a fill to match the gable fascia, copy it to floor plan infill with a slab with the desired thickness, select it and view it in 3d, set the parameter to side view in navigator and rear view at 90 deg. , then go to GDL Objects in file menu, save 3d Object as.... and save it as a library part.
2005-03-03 04:39 AM
2005-03-03 04:26 PM
2005-03-03 04:39 PM
2005-03-03 05:04 PM
2005-03-03 06:03 PM
Peter wrote:Perhaps I am using inccorect terminology, but in essence that what profiler allows you to do. The "profile" or section view can have a curved shape, and the path you define can also be curved. The last step was simply standing the library part we made with profiler "up". I am sure you could do this last step with GDL and avoid having to create two library parts that you need to load with the project, but this forces one to enter the world of GDL scripting.
Mike,
How does your method allow curvature in two planes ?
I am assuming that you are using AC's Profiler.
Thank you,
Peter Devlin
