2026-09-22 02:42 AM
I have already made a custom cabinets. Now i want to increase its height, add new drawer, change material and delete some parts.
So how can i edit it so easily and quickly?
Solved! Go to Solution.
2026-09-22 03:10 AM
Well, if your carcase is a seperate morph to your drawers, you could isolate it in 3D then use Sub-element Selection to select all of the upper elements, that you can then move vertically the required amount.
Then do the same with your drawers, prior to duplicating.
Ling.
2026-09-22 03:01 AM
How did you create it?
2026-09-22 03:03 AM - edited 2026-09-22 03:07 AM
By morph tool. Now i am editing that on 3d window but it takes lots of time. So, i am looking for easiest way
2026-09-22 03:10 AM
Ling.
