8 hours ago
Hi!
My question is, in a renovation and to use properly the renovation filter, is it possible to demolish just the flooring of a slab (composite)?
Z
7 hours ago - last edited 7 hours ago
i think you need to create an independent skin for the demolish part of the slab
6 hours ago
Or you can define the finish as finish (in composite) and then do a Partial structure display and make it show only the ”core”. I know it is not directly linked to the renovation filter but its a faster way to generate your desired view.
6 hours ago
Or create a second composite slab without the demolished skin, in case this retains some modelling or BIM balance.
5 hours ago - last edited 5 hours ago
I want to demolish the ceramic finish and place new wood floor. Assuming we only need to demolish the ceramic and not the concrete base above the slab, your advice is to create a slab without the finish and then create :
1. Tile floor layer (and check it as "demolition")
2. Wood floor layer (and check it as new construction)?
Would i have to use the "slab" tool to create those finishes?
Z
5 hours ago
Νο. Create the first slab with the the tiled floor. Check the slab as to be demolished.
Then a second slab with the wood floor. This slab will be the new construction.
Keep the concrete or any other layer in both slabs.
Just create two composites.
3 hours ago - last edited 2 hours ago
Yes, @Zendrix, keeping one structural slab with two finishes (one demo and one new) would be the best thing, IMHO. Creating two completely separate slabs (with their respective finishes) will mess with your scheduled quantities.
