Dimensioning in core only and entire structure combo
ratnabhirud
When I dimension something in entire structure combo in Quick Option Palette, and when I switch to Core only option, Dimensioning disappears.
Similarly, Window sill is not visible in Core only option, when I put them in Entire Structure option.
Is there any solution for this?
Regards,
Ratna
AMD Ryzen 5 3600 6-Core Processor 3.59 GHz
Ram - 16.0 GB
System - Windows 10 Ultimate, 64 bit
NVEDIA GForce 8400GS
Archicad 9..., 24
Dimensions are Partial Display Option-specific so you need to dimension in each of these different view separately.
About Sills: My guess is that you would have to modify the GDL script of the Sill and Board macros because they probably read the value of the Partial Display Option and draw or not draw the Sill/Board in 2D accordingly.
ratnabhirud
Thanks a lot laszlonagy,
Is there any solution for my post which I have asked on Sep 16 , 2012 , regarding importing Surveyors data directly in to Archicad?
Regards,
Ratna
Ram - 16.0 GB
Archicad 9..., 24
