Bohdan_K
Displaying Blocks on Plan
Hi All,
I'm currently working on a project in ArchiCAD and need to display actual 440x140mm blocks setting out on the plan, rather than the classic cut block diagonal hatch. (see attached snip)
Are they any ways to do that instead of just drawing 2D on top?
Thanks,
B
1 Reply 1
Steve Jepson
Did you try changing the Building Materials "Structure and Appearance" ?   You might try assigning or making an new Surface Texture.
