Door In Complex Wall Profile Incorrect
We have a complex wall profile that has a 4' wainscot and a ledge. When we place a door in the wall, it displays incorrectly in both the plan and 3D. In the plan view, the door frame is correct, but it doesn't cut the ledge. In 3D the door frame extends all the way to the end of the ledge. Any ideas?
17 REPLIES 17
adzik
have you tried turning on the Frame Depth=Wall Depth setting under Door Frame parameters ?
Running ArchiCAD 23 INT.
adzik wrote:
Yes, I've tried that both ways.
Can you tell us what the exact name of the library part is that you are using?
Also, it would be fastest for one of us to diagnose this if you could post a zipped module if possible. Do the following: select the wall that contains the problem door. File > External Content > Save Selection as Module. Zip the resulting MOD file and attach here.
The profile (attribute) for the wall will come along with the module, but nothing much else - tiny file. Any of us can then merge your module into a default template to see what's going on.
Thanks,
One of the forum moderators
AC 28 USA and earlier   •   macOS Sonoma 14.7.1, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thanks for looking at this - I've attached the module.
No joy here. Sorry.
You used non-standard library parts, but I tried standard doors and got results similar to yours even after putting the opening reference line back where it belongs in the profile. (Was out in space in the MOD.)
Better results with 12, but still had the frame floating in space - or cutting through the chair rail.
No quick ideas from me - hopefully somebody else can figure this out.
Well, thank you very much for looking at it.
adzik
Maybe just turn off casing on the door and create it manually with slabs/beams/columns.
That was the only way I could get it to work. Although I'm rather sure that in an older project I was able to achieve it without the manually added elements. If I should remember I'll let you know.
Ya - I did end up turning the casing off out of frustration and manually creating the casing with fills in the section drawing.
THe other issue with this is that the door does not cut through the chair rail in the plan, so the chair rail is continuous in plan - no matter where I put the opening line in the complex profile.
Kinda frustrating.
