‎2014-06-27
04:39 PM
‎2023-05-24
08:58 AM
Rubia Torres
‎2014-06-30 07:41 AM
s2art wrote:This is the way we do.
Why not have the Structural slab at 0 elevation, with the base of walls at 0, and thin finishes slabs above that? Undercut doors by 20mm and take finishes into openings, as it would be done in reality.
‎2014-06-30 09:51 AM
‎2014-06-30 10:35 AM
dan_g wrote:Seems like you have logged on as a new user (you now have a total of 3 posts with this login).
Bit baffled about my signature, someone pointed this out before and I added one - but sure enough it isn't there now. Will get that sorted.
Thanks again all.
‎2014-06-30 11:10 AM
‎2014-06-30 11:20 AM
dan_g wrote:Yes you are right.
... Confusing if your looking to BIM/IFC the project outside of your office.
‎2014-06-30 11:26 AM
‎2014-06-30 04:14 PM
Barry wrote:Unfortunately this is not possible to do.
I'm not sure if Laszlo (the administrator) can transfer your 'dan_g' posts to 'Dan G' (or the other way around).
‎2014-06-30 11:18 PM
alemanda wrote:That's blasphemy!uisanata wrote:Reality is usually much more complicated than composites possibilities.
It's true that you should model the way it's built, but there is no reason why you shouldn't use the composites. Two slabs on top of each other must be a pita to model / modify / update. The same with wall finishings. How do you insert a window or a door in multiple walls?
Multiple walls = multiple doors. For example when we model stone cladding we insert a door in the block work and an empty door(I mean just the hole)in the cladding (which isusually done with a double wall parallel to the main block work wall)
In this way we can control the model in a perfect way. Of course we have an addintional amount of work. But usually we do this when we have to produce construction drawings.
‎2014-07-01 02:09 AM
uisanata wrote:Just out of curiosity: how large is that project in terms of square meters?
I am currently working on a project with 8000 doors. Imagine modelling another 8000 ! and documenting all those slabs and walls in 5000+ construction details....
