‎2014-06-27
04:39 PM
‎2023-05-24
08:58 AM
Rubia Torres
‎2014-07-01 03:08 AM
uisanata wrote:alemanda wrote:That's blasphemy!uisanata wrote:Reality is usually much more complicated than composites possibilities.
It's true that you should model the way it's built, but there is no reason why you shouldn't use the composites. Two slabs on top of each other must be a pita to model / modify / update. The same with wall finishings. How do you insert a window or a door in multiple walls?
Multiple walls = multiple doors. For example when we model stone cladding we insert a door in the block work and an empty door(I mean just the hole)in the cladding (which isusually done with a double wall parallel to the main block work wall)
In this way we can control the model in a perfect way. Of course we have an addintional amount of work. But usually we do this when we have to produce construction drawings.
Just kidding😉
I am currently working on a project with 8000 doors. Imagine modelling another 8000 ! and documenting all those slabs and walls in 5000+ construction details....
I must contradict you, composites are working just fine, if you know what to use them for. I don't think that GS guys created such a great tool if slabs were better. How do you manage the line between 2 slabs in section view? Which line is visible and which is not? How do you intersect slabs wth walls and roofs? Don't you use the priorities?
Try it, it will grow on you...!
dan_g wrote:Hello everyone.
Otherwise how do you deal with changes in covering from room to room? Answer: You have a tonne of fragmented structural elements. Confusing if your looking to BIM/IFC the project outside of your office.
‎2014-07-01 06:00 AM
alemanda,I would
Would you find it useful if the skins of a composite could be manually adjusted as if they were independent slabs or walls ?
‎2014-07-01 08:04 PM
laszlonagy wrote:300.000 sqm.uisanata wrote:Just out of curiosity: how large is that project in terms of square meters?
‎2014-07-01 08:21 PM
sinceV6 wrote:You're funny.
why have 3 or 4 structural elements defining the one-and-the-same slab (just because of the finishes?!?)
‎2014-07-02 01:20 AM
uisanata wrote:You're probably missing the point.sinceV6 wrote:You're funny.
Why have 3 or 4 slabs defining the one-and-the-same object, when you can have just one?
‎2014-07-02 07:54 AM
Steve wrote:It would be useful to have clean plans and sections.
alemanda,
‎2014-07-02 07:56 AM
sinceV6 wrote:+1
Please share a solution using a single composite that accommodates different finishes and levels grouped by arrow color in attached section scheme; so that the core/slab is only one...
maybe I'm missing something.
I apologize if I misunderstood what others are saying regarding composites and multiple elements.
‎2014-07-03 09:58 AM
‎2014-07-03 09:59 AM
