2007-08-01 02:22 AM - last edited yesterday by Aruzhan Ilaikova
2007-08-01 02:49 AM
2007-08-01 02:55 AM
2007-08-01 02:57 AM
Peter wrote:
Hello Ignacio,
Could you model one of these precast panels with the mesh tool
and save it as a library part, and rotate it to the vertical ?
Just a thought.
Peter Devlin
2007-08-01 03:03 AM
2007-08-01 03:49 AM
Peter wrote:The geometry of the thing is freaking impossible, I just spent 1.5 h on it. Either I spend two days ArchiCAD-drafting the descriptive geometry exercise with a bunch of auxiliary planes on the sort-of-paraboloid-like faces and then trace the resulting contour lines with the mesh, or I dumb it down and it will look clumsy.
Why don't you think it will look very good as a mesh ?
2007-08-01 04:10 AM
2007-08-01 04:46 AM
2007-08-01 06:18 AM
Peter wrote:Thanks for the suggestion! I would not have tried so hard had it not been for the suggestion, at least not at the start. Now I know that if I go the way of the mesh I should aim for some approximate resemblance only.
Hmm... I did not know it was so complicated.
Sorry for the suggestion.
2007-08-02 01:22 AM
