2009-03-11 01:39 AM
2009-03-11 02:28 AM
2009-03-11 01:11 PM
2009-03-11 08:31 PM
2009-03-15 09:09 PM
2009-03-15 11:25 PM
2009-03-16 12:08 AM
2009-03-16 12:20 AM
Starchi wrote:Project North shouldn't affect your angle input if it is set to degrees, minutes, seconds. It will only affect angles if the angle input is set to surveyor's units.
Hi Dwight, S2art and Jocontreras,
Thanks for your help. Yeah, I will try to use the Site tools today.
Last question, does project north has any effect on degree min sec input?? becasue, it seems different when compare with the survey drawing!!
Star
2009-03-16 02:45 PM
Link wrote:Project North can accept numbers up to 4 decimal points, go to Project Preferences > Working Units & Levels > Angle & Text Size Decimals in Dialog Boxes: you have options 0 to 4. Even if this is set to less than 4, you can input a number with 4 decimal places for the Project North in the Sun dialog box and ArchiCAD will use the extra decimal places.
I have heard that either way, since Project North only allows fordecimaldegrees (accurate to just 2 decimal points) there can be a small discrepancy compared to an actual sureveyor's measurements.
2009-03-16 10:12 PM
