Elevation drawing Problem
Hi everyone;
North view of my project was that picture (pic - 1). But took this form after struggling with something (pic - 2). Also I do not see my windows in the floor plan. How do I go back into the past (look like pic - 1). What settings I need to change . I need your help . Thank you all...
Pic - 1
Pic - 2
5 REPLIES 5
Dontknow
I think you must set your 'model view options'.
You can also set it at 'Quick Options'.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
or here ?
Thank you so so much! My elevation view problem was solved by you. However, doors and windows in the floor plan still does not appear. Do you have any information about this problem? Thank you again...
Steve wrote:
or here ?
could be missing library or library needs to be reloaded. ?
David Maudlin
Look at Model View Options > Options for Construction Elements > Door Options. Or this could be due to the height of the Floor Plan Cut Plane if the Walls and Doors are not set to Symbolic.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
