Ending a continuous wall
arg617
I'm working through a tutorial and drawing a railing. I'm using a complex profile and the wall command, with 'continuous' clicked on.
How do I end the continuous wall? I tried hitting 'enter', 'escape', double clicking, searching online, but can't seem to figure it out. Of course it's probably something very obvious.......
Anyone care to share? Thanks
7 REPLIES 7
Eduardo Rolon
On the last segment click to place it and then click on the same spot again (black pencil icon).
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
arg617
Thanks for the quick reply! I'll try it
David Maudlin
arg617:
Another way: if the Control Box palette is displayed, you can use the "OK" button.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Or: right-click and select the OK command from the appearing context menu.
It would also be efficient if ArchiCAD would end & close a line, wall, fill, slab, etc. with a simple keystroke; (like maybe cmd-enter or something.) Even though it only saves one click, it does ensure that the element is closed.
David Maudlin
For the polygonal tools (Slab, Roof, Mesh, Fill), double-clicking the last node closes the polygon.
The existence of the double-click feature is understood. However, it would still be efficient to have a simple keystroke that would achieve the same result without having to go back to the first node.
