2009-12-18 03:53 PM
2009-12-18 04:39 PM
2009-12-18 04:40 PM
NStocks wrote:You need to drag a copy of your elevation and edit the copy lines otherwise when you regenerate your section from the model the elements will be replaced and all your edits lost.
I want to make these lines straight ( attached ) or at least erase then and draw on new ones. How can I erase part of a line and re-draw it, without deleting the whole component?
NStocks wrote:If you Rebuild from Model the changes will show.
Also, when I unlink a elevation, I no longer have the option to change the elevation settings, so I now have to ensure all elevation settings are changed before unlinking the elevation from the model. Why is this ?
2009-12-18 06:41 PM
