Error when 3d view is displayed
To All,
Please see the attached error.
Please help. It appears all the time while initiating the 3d window.
Thank you
Best regards,
DDJUSA
6 Replies 6
Ben Odonnell
DDJUSA,
Unfortunately I'm not familiar with the US library. Could it be a door or window has a wrong setting some where?
HTH.
Cheers.
Ben
Ben O'Donnell
Ben,
Thank you for the fast response.
I don't think there are any doors or windows out of sync.
This error comes up on a brand new drawing with few elements.
Best,
DR
I think too, it is something to to with GDL-Objects.
Try to reloade the library
Ben Odonnell
DR,
As Jakop stated, there is a library prat some where in your model that has a wrong setting. I don't think reloading your library will do the trick though.
You will need to track down the problem object/s and fix the wrong setting.
HTH.
Cheers.
Ben
Ben O'Donnell
Djordje
Switch your Report window on. It will tell you if there is an error, and in which library part. Use Find&Selct to find it, correct the wrong parameter, and that should be that.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
DDJUSA wrote:
To All,
Thank you
Best regards,
DDJUSA
The 'Polygon degenerated' message means that a polygons-shaped 3D body within the named GSM file is not correct. This is probably caused by parameters not set correctly or set in such a way that is creating a degenerated 3D body.
I am not familiar with the US library either, but from the word 'Trim' in its name I guess it might be a Window or Door.
Try finding which Window/Door in the file where you have few elements placed. To do this, select one Door, display it in 3D and see if the message appears. Find the Door/Window which produces the message when displayed in 3D by itself.
You may also try turning off Trims for those placed Doors/Windows and see if that helps.
You may also post a zipped small PLA file with the problem reproducible in it so we can check it out.
