Error when 3d view is displayed
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2005-04-07
07:29 PM
2023-05-26
03:15 PM
Rubia Torres
2005-04-07
07:29 PM
Please see the attached error.
Please help. It appears all the time while initiating the 3d window.
Thank you
Best regards,
DDJUSA
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-04-07 08:06 PM
2005-04-07
08:06 PM
DDJUSA,
Unfortunately I'm not familiar with the US library. Could it be a door or window has a wrong setting some where?
HTH.
Cheers.
Ben
HTH.
Cheers.
Ben
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-04-07 09:13 PM
2005-04-07
09:13 PM
Ben,
Thank you for the fast response.
I don't think there are any doors or windows out of sync.
This error comes up on a brand new drawing with few elements.
Best,
DR
Best,
DR
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-04-07 09:59 PM
2005-04-07
09:59 PM
I think too, it is something to to with GDL-Objects.
Try to reloade the library
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-04-08 09:08 AM
2005-04-08
09:08 AM
DR,
As Jakop stated, there is a library prat some where in your model that has a wrong setting. I don't think reloading your library will do the trick though.
You will need to track down the problem object/s and fix the wrong setting.
HTH.
Cheers.
Ben
HTH.
Cheers.
Ben
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-04-08 09:30 AM
2005-04-08
09:30 AM
Switch your Report window on. It will tell you if there is an error, and in which library part. Use Find&Selct to find it, correct the wrong parameter, and that should be that.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
HP Omen
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-04-12 03:15 PM
2005-04-12
03:15 PM
DDJUSA wrote:The 'Polygon degenerated' message means that a polygons-shaped 3D body within the named GSM file is not correct. This is probably caused by parameters not set correctly or set in such a way that is creating a degenerated 3D body.
To All,
Thank you
Best regards,
DDJUSA
I am not familiar with the US library either, but from the word 'Trim' in its name I guess it might be a Window or Door.
Try finding which Window/Door in the file where you have few elements placed. To do this, select one Door, display it in 3D and see if the message appears. Find the Door/Window which produces the message when displayed in 3D by itself.
You may also try turning off Trims for those placed Doors/Windows and see if that helps.
You may also post a zipped small PLA file with the problem reproducible in it so we can check it out.
