Fix found: Archicad 28 lagging issues
Richard Houlahan
Not a question but rather a solution if anyone has similar problem.
Using Archicad 28 with CI Tools (Aus/NZ) I was modelling a roof using Roof Tile.
I usually use the Shingle Tile cladding but thought the Roof Tile was more accurate for the job.
After applying the cladding anything I tried doing in 2d on a layout like dragging elevation viewports around or dragging text boxes took unbelievably long to click select and drag.
Reverting the roof cladding to the shingle instantly solved the lag problem.
Hope that helps someone with similar issues.
Operating system used: Windows 11 24H2
2 ACCEPTED SOLUTIONS
For a shingle, Archicad only has to calculate one flat slab.
For every tile there are many many polygons in 3D and extra lines in 2D.
It may also be defining and calculating the tile fill in 2D.
The less detail you can get away from modelling, the faster Archicad will be.
AC28 has made 3D navigation extremely slow i've discovered.
Using the same file in AC26 and AC28; AC26 can load a 3D full of textures, metal cladding, etc. instantly. Open the same file in AC28 and it takes 30-60 seconds to generate.
Even simply unlocking a layer is causing a full 3D regeneration....
4 REPLIES 4
Lingwisyer
Guru
Though it should not be redrawing the shingles when moving things around on the Layout without resizing anything?
MarkT
I'm getting the same insane lag but my roof object is a flat sheet, the profile is controlled by MVO for Elevations & 3D presentation so in normal plan view it's not req'd to have a profile. Also, since installing the latest hotfix 27.3.2 for AC27, I now have the same AC28 lag in AC27. Moving object text can take anywhere between 10-20sec to complete the move. This is getting incredibly frustrating.
PS I should probably add that we've just migrated to cloud licensing which is likely the issue and seems to come with a fair amount of on-line complaints. I believe GS are working on a bugfix if what I've read is correct.
AC3.14 (1990) to AC28 (2025)
PC : i7 7700k @ 4.2GHz - 32GB - W10/64
Setup info provided by author
