2009-03-26
05:29 PM
2023-05-25
05:09 PM
Rubia Torres
2009-03-30 11:19 PM
2009-03-31 03:46 AM
2009-03-31 08:22 AM
Peter wrote:The SEO operation I was referring to is ISECTLINES. It is a special form of intersection, not present in ArchiCAD itself but only in GDL, that generate the intersection lines, without surfaces. I use it with the full mesh as the target and the cut mesh as the operator. This way I can do the whole thing without knowing the mesh size (the cutplane is infinite).
Hello Roberto,
I downloaded your object and looked at the script
and found that you used the CUTPLANE command
to do the cutting of the object called in the script
rather than SEO (or the group operations equivalent)
as you stated.
I changed the "contour line step"Sorry... it was metric.
parameter from 3'-3 3/8" to 1'-0" and got an error
saying "group operations error at line 21 of the 3D
script of...etc". I checked script but no errors are reported.
Looking at the script I can't see what the problem might be.
Why is calling the object more than once not desirable ?Only for the "waste" of time and computing resources!
I can see using a series of slabs separated by a very smallAs I said , this requires to know the size of the Mesh, in order to make the slabs big enough.
space and using group operations to leave very thin slices
of the object could be done but why ?
2009-03-31 11:19 PM
2009-04-09 01:59 PM
2009-04-09 03:43 PM
2009-04-09 09:19 PM
Mark wrote:Thanks for the appreciation. And it is so simple to make, that I'm surprised no one (including me) did it before
Roberto,
I really like this object - thanks alot.
2009-04-10 01:27 AM
2009-11-05 08:15 PM
2017-04-19 08:14 PM
