Eric Milberger
HC Railing.
Do we have a tool for railing that can create the US standard.  I don't believe what we have will .
The tool does not seem to be able to follow the floor as required.
Eric Milberger, Architect | Master Planner
3 Replies 3
Lingwisyer
Guru
Place two handrails and use the Full Return option for the top one? Do not believe there is any way to do the pipe fixings.
Eric Milberger
Will try however this should be much easier as in a standard rail already in the template (For example this is a pain, and you cannot just extend to floor.  As in extend to floor from stair - you MUST go into 2d and locate the starting point. This should be better out of the box with a ramp rail (side and center rail version) a stair rail and a mid-rail Version plus the single for aisles at seating.
Eric Milberger
That does not meet code.    I don't know why we don't have saved ones that do follow code..   very challenging  to make work.   The build may be cheaper than the model
