Betencorte
Hole in column
How to use the opening tool with the column element type? Is there a way of creating holes for the mep routings to pass?
aarkell
I don't believe the opening tool works on columns. You could use an solid element operation to cut a hole with the subtract function. Or you could use a beam or other object in the shape (complex profile) of the hole you want, to "cut" the column by using a stronger building material and putting it on a hidden layer.
Andrew Arkell
AC 18-27 USA 5030
HP Z6 G4 Workstation | Intel(R) Xeon(R) Gold 6226R CPU @ 2.90GHz | Windows 11
