‎2004-05-06 04:16 PM
‎2004-05-06 06:37 PM
‎2004-05-06 08:51 PM
Link wrote:Thanx Link! I actually came up with the same work around (hotspot) but I thought there would be a clever way to do it properly. Where can I find the script for the differnt lines? I recon they are GDL-objects so I shluod be able to change the code manually to get it right.
I know that you can add a hotspot in your linetype to center the line's origin. Just add the hotspot at the same distance above the center of the line, as the distance to the bottom most part of your line. (If that's not clear, let me know and I can post an image)
‎2004-05-06 09:13 PM
‎2004-05-07 10:15 AM
‎2016-07-16 01:00 AM
‎2016-07-18 03:21 PM
‎2016-07-18 07:08 PM
‎2018-03-26 05:33 AM
‎2018-03-29 04:09 PM
