How can i change the orbit shortcut in the mouse ?
how can i change the shortcut of the orbit -in the selection mode- which is as default (middle mouse button + shift) to be only by clicking on the middle mouse button just like SektchUp.
as i am using both softwares, it make it a way harder for me to work fast on my projects
if any body has any idea plz share it with me
4 Replies 4
Erwin Edel
Don't think you can reassign it in ArchiCAD, however you might be able to use software for your mouse to setup a profile for ArchiCAD to change behaviour of the button.
'O' also activates orbit, if that helps.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
thanks for your reply, can you point to a specific software name ?
Lingwisyer
Guru
Depends on you mouse manufacture. If you use a Logitech mouse, it would be LGS or Logitech Options depending on whether you are using one of their gaming or office mice. Razer has a program called Synapse for their peripherals. Other brands have their own. Some that work well, others that do not. I do not know of any generic software to do this as it has to do with the mouse drivers but there might be something around...
Ling.
Erwin Edel
I use setpoint for logitech, but as pointed out by Ling, that most likely only works for logitech mice.
Unless you have some extremely cheap non-brand mouse, there would be something out there.
www.leloup.nl
