Roopa A
How do we save template with the palettes
I need to save the template with palettes as default like 3d visualization, control palette, profile manager,
So that I need not to open and dock the palettes for all my projects.
Roopa A S
4 Replies 4
runxel
The palettes and their position is part of your Work Environment, not of the Template.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
Patrick M
make sure you save, store, and apply as default with any changes to your work environment (options > work environment > work environment). The set as default is critical, so that every AC file/instance you open uses the set w/e
Roopa A
For all the new projects, we have open those palettes all time.
Or we have to use the current profile in the New project?
Roopa A S
Guru
Can you take a screen shot of the Work Environment page that 4dProof pointed to? In both a new file and a project that has all your palettes set up.
