How to Draw This Kind of Wall?
Hi there
I am working on archicad for 4,5 months, and I faced a problem today, and found your forum.
I would really appreciate you, if you help me to draw this kind of wall.
I attached the shape of wall here.
please answer me as soon as you can, because I have a presantation the day after tomorrow.
Your care is highly appriciated.
Thnx
30 REPLIES 30
Eduardo Rolon
It will be a regular wall with a roof to define the point and angle at which it is cut then you can use SEO (solid element operations) with the subtraction with upward extrusion setting or the trim to roof command to subtract the shape. The roof used for the trim should be on its own layer so that it can be turned off.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Rakela Raul
http://archicado.free.fr/
sorry.bad link!!! click on "archicad objects" them "techniques", there u will see your wall
fifth object - top row
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
@Rakela Raul
Oh man, you made my day.
Thannnnkkkkk Youuuu...
I did what you say and now I`m really happy not only for the wall, but also for the fantastic objects I downloaded from the site u said.
If you have more references for Archicad11 objects specially landscape objects like this site (free ones I mean), please let me know.
I really need such sites for my job.
again thank you.
@ejrolon
As you see I solved my problem but I could`nt fully understand the method you said.
and also I saw this in download.archicad.com/ftp site, but again I could`nt made it.
If you can tell me in details I would really appreciate your care.
sorry for my rudeness, but please tell step by step so i can made it.
or give me a site, that will do that please.
Thanx all you man.
for everything
Thomas Holm
The Archicado item is an object, and as such will not clean up with oter walls. If you want that you need to use one of the procedures ejrolon describes.
Read in the Help menu about
1) the Trim to Roof command, and about
2) Solid Element Operations (SEO)
Especially the latter is extremely useful in many situations.
Ihave another question and that is,if i want to have different kind of material in walls what should ido..idraw a wall and the next that i want with different kind of material but it makes all similiar,it makes me mad
tnx
Dwight
Help me understand the excitement.
You can easily make a wall with a sloping top in two simple ways:
1: Using a mesh
2: Using a roof element to trim a wall, thereby preserving all of the wonderful things a wall does, including supporting windows and doors.
Dwight Atkinson
Rakela Raul
@Rakela Raul
relax !! only because you are in hurry with this simple wall....if you want to do it right....follow everybody else advise.
This is something that must be tested: What happens to the integrity of the model if you must use a nonexistent roof to make the wall you want. What happens if you export this combination to IFC? What is the clean way to do this?
More and more, what is expected from us is a model that IS right instead of just LOOKING right.
Anssi
Dwight
Fair enough question, and one that affects any subtractive process in Archicad.
What about any SEO operation where an operator is extra to the model?
Does anyone have the answer?
PS: How far are you away from where they have the wife-carrying contest?
Dwight Atkinson
