How to boolean (substract) many morphs at one time
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2021-05-04
03:08 AM
2023-05-24
07:20 PM
Rubia Torres
2021-05-04
03:08 AM
I have many morph elements need to be substracted by one source morph,
but "substract tool" can only substract one element once --- any advice,
(PS, for simplicity, I don't want SEO)
Thanks
Solved! Go to Solution.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-05-04 03:29 AM
2021-05-04
03:29 AM
You can 'Union' those multiple morphs into one morph - but they will no longer be separate morphs.
This shouldn't be a problem if you aren't going to change or move them.
You can split them again later if need be, but that might be a tedious process.
I would just SEO.
Then you know the connection is live and will adjust if your morphs are moved.
I would just SEO.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-05-04 03:29 AM
2021-05-04
03:29 AM
I would just SEO.
I would just SEO.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-05-04 03:42 AM
2021-05-04
03:42 AM
OK
though there will be a bit complicated to modify again,
Thanks Kerry
Thanks Kerry
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-05-08 04:01 PM
2021-05-08
04:01 PM
Here is what you can do:
1. Select all Morph elements you want to subtract from, select them as Targets in the SEO Palette, and Subtract the other Morph element from them in a single step. Now, there will be an associative relationship between each of them and the Morph that was subtracted from them.
2. Now, select all the target Morhps again, and use the "Design > Convert Selection to Morph(s)'" command. Each Morph will be converted into a separate Morph element (even if their geometries collide in 3D), with the SEO applied, but no longer associated with the operator Morph element.
