3 weeks ago
This is possible or not to Create a Pattern wall in plan difference with section.
Refer to image 1(wall plan) is use diagonal. And Section i would like to change pattern to Horizontal double line.
Thank you so much for suggestion.
Solved! Go to Solution.
3 weeks ago
You can achieve your desired representation by using graphic overrides. Basically, you tell Archicad to replace, in sections or any desired views, all the wall cut fills with a different cut fill. You can have different fill colors etc.
More on that here: https://help.graphisoft.com/AC/24/int/_AC24_Help/050_ViewsVB/050_ViewsVB-134.htm
3 weeks ago
3 weeks ago
Thank you so much.
3 weeks ago
But keep in mind that Graphic Overrides always affect the whole element. In case of Composite Structures and Complex Profiles, that can lead to unexpected results, like your example where all three skins of the Composite will be overridden with the spacified fill.
3 weeks ago
This is also a problem that GS should have solved a long time ago.
Resources shouldn't be wasted on beautifying kitchen cabinet handles, but on important things like this...
Gábor
