How to cut beam on specific spot?
Noody
Hello everyone,
I have a question about cutting beams at a specific spot. Is there any way I can cut the beam at a specific spot, as shown in the picture? I need to make a custom truss for the roof, but also for the project plan, i need to have that cut part on the timber so it can be shown where to cut it and on which angle and etc... I tried to explore some of the things to make my own beam with cut on specific distance, but i was not able to make it.
Jaime-airc_digital
The easiest way is to use the opening tool on each beam:
Opening tool on BeamOpening tool on Beam
Archicad 28 ARM, MacBook Pro M3 Max 128Gb, macOS Sonoma.
/Operations Director /BIM Lead /Architect @ www.airc.digital ltd ™
M Architecture & Urbanism ARB
1 REPLY 1
Jaime-airc_digital
Setup info provided by author
