How to draw this kind of wall?
Hi there
I want to know How to draw this kind of wall?
tnx
14 Replies 14
Eduardo Rolon
Under the Design Menu navigate to
-> Complex Profile
-> Profile Manager
__
1. create a new profile click on the " New" button
2. in the window draw your wall section with a fill
3. store the profile by clicking on "store profile"
4. apply the profile to the wall by selecting the button labeled 'apply to selection"
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
TomWaltz
masoud_s66 wrote:
I did read all of them,but I cant do it now,please explain how can I do it step by step
What have you tried so far and what about it did not work?
Tom Waltz
design > complex profiles > profile manager > new
this will open the profile manager
using the single hotspot thats in that window as the location of your referance line/point, use fills to draw a cross section of the wall profiel your after.
once your done, hit "store profile"
then in your wall tool push the complex profile as the wall method/complexity
then under structure, select the profile you drew in teh 1st step
"then in your wall tool push the complex profile as the wall method/complexity
then under structure, select the profile you drew in teh 1st step"
where is complex profile in the wall tool?
David Maudlin
Here.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
