LeeJaeYoung
How to make a window visible in a floor plan?
The problem is that GL is on the first floor and the gap between it and the first floor is only 100mm, so the windows do not appear on the first floor.
How can I show it?
2. Of course, if the wall standard is GL, it is visible from the GL floor.
The problem is that the window is so high that the Cut Height cannot be raised that much.
What should I do?
AC27 on window 11
5 Replies 5
LeeJaeYoung
I thought wrong.
I only changed the cut plane height from 1000 to 50...
The floor needs to be 2nd floor.
sorry.
AC27 on window 11
Guru
If your FPCP cuts the wall in question, and the wall is set to display on the relevant storey, you can set the wall to Symbolic Cut. This will make all the doors and windows hosted in the wall to appear cut even if the FPCP does not actually cut them.
Ling.
LeeJaeYoung
It is meaningless if you do not touch the relative floor plan range. ^^
Thank you for answer.
AC27 on window 11
Guru
If you are only "cutting" the window and not the wall, an option would be to place a second window in a wall above and turn off it's 3D display, then seperate it's classification so that your can exclude it from your schedules.
LeeJaeYoung
thank you so much ^^
AC27 on window 11
