How to make curving walls n windows that also vary in height
Hey,
I am currently working on a case study on the Wall House #2 (Bye House) by John Hejduk and I am having some real difficulty in attempting to make the windows and ceilings for some of the spaces he has designed. If you take a look at a picture it will probably help to see what i am talking about.
http://i-eclectica.org/wordpress/wp-content/my%20images/architecture/Hejduk/Wall%20House%202-5.jpg
Anyway what would be the best way to achieve these forms in archiCAD any help would be most apprecciated.
Thank you!
6 REPLIES 6
The walls are just curved walls. Top walls is just trimmed to the roof surface.
The windows, being true curves, have to be modeled with walls and/or custom objects. The top story is easy - just model the entire wall, sill and window as one complex profile, then add dividers.
Bottom story looks like a flat surface. Create a custom freeform window using slabs, including the curved sill.
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
the g/f is still so difficult to be done,
can anyone achieve it and explain further more?
Erika Epstein
What is "g/f"?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Erika wrote:
What is "g/f"?
Ground Floor, I expect!
You can draw a custom window of any shape on plan using slabs and walls, and define a separate slab as the actual wallhole that cuts the opening. Simply change the slabs ID to "wallhole" and save the whole lot as a window.
For full details do a search for 'wallhole'. It has been discussed many times before. It is also described in the ArchiCAD help file.
Press f1 and go to - 'Virtual Building : Parametric Objects : Graphic Creation of Custom Objects'
Hope that helps!
yes i mean ground floor
but after having a window opening, how can we place a window into it? use curtain wall???
Djordje
You can. Also, you can model the window with the wall tool.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
