2010-01-21
02:45 PM
2023-05-25
06:07 PM
Rubia Torres
2010-01-22 03:52 AM
2010-01-22 08:32 AM
2010-01-22 08:38 AM
2010-01-22 10:19 AM
onsnapcad wrote:The curves are made with walls. In fact it's all made of walls except the columns for the vertical trims in the assembly model (which become the horizontals in the installed door) and the slab for making the wall opening.
...and Matthew if you can explain your method to do the curved part...
2010-01-22 04:49 PM
2010-01-23 05:36 AM
2010-01-23 09:29 AM
2010-01-23 11:11 AM
onsnapcad wrote:OBJECTiVE can easily handle profiled compound curves - I posted an example at the following link:
now another challenge, thanks to the help from Erika and Matthew I was able to create the arches including one with an ellipse, but now another thing came up.. javascript:emoticon(':?')how do I model the same coffer detail for the three arches that are in a curved wall, is there a way to bend an object any ideas... thanks!!
