2010-11-07 01:30 AM - last edited on 2023-05-25 05:05 PM by Rubia Torres
2010-11-10 12:38 AM
2010-11-11 03:30 PM
NStocks wrote:Try the following process, referring to the attached image. Also, make your building an OBJECTiVE
I've attached a image of the piece that needs to be extended... It needs to be at an angle though because it has been rotated at an angle, the bottom line is not straight, it needs to be extended to the floor...
2010-11-11 07:10 PM
Ralph wrote:Works perfect! I also forgot that I can split and rotate OBJECTiVE cinponents in Elevations too which saved a lot of time.NStocks wrote:Try the following process, referring to the attached image. Also, make your building an OBJECTiVE
I've attached a image of the piece that needs to be extended... It needs to be at an angle though because it has been rotated at an angle, the bottom line is not straight, it needs to be extended to the floor...assembly, which means you can always return it to its original position after rotating and reshaping. I hope this helps.
- 1. I've mocked up something like your image.
2. The first step is to get an orthogonal view on the face to be reshaped. In this case I've opened an elevation onto the face, and tilted the model so the face is vertical.
3. Draw the shape you would like the face to be with the fill tool (trace over the elevated model). Then select the fill and face object, and useOBJECTiVE > Component > Change Profileto reshape the object.
4. This finished surface in elevation...
5. ...and in 3D.
2010-11-14 06:37 PM
2010-11-15 10:07 AM
2010-11-15 10:40 AM
NStocks wrote:I'm struggling to get past thinking, "how would I construct something like that, i.e. in real life?"
I've tried doing it on a elevation but because the geometry is so angular, I always end up with gaps due to the elevation angle against the frame angle.
Looking at the image, how else could I go about adding pieces to this frame ? Would the 'assembly' work in 3D better than using the Elevation profiles
2010-11-15 11:18 AM
2010-11-15 04:20 PM
Ralph wrote:I've managed to change the frames with OBJECTiVE and I'm now adding the panels with the Mesh tool, via the mesh-to-roof add on.NStocks wrote:I'm struggling to get past thinking, "how would I construct something like that, i.e. in real life?"
However, I think the answer lies in the fact that you can't solely construct this shape from the plane of the floor plan or an elevation. You will have to frequently reorientate the objects or assemblies that make up this structure to get a clear handle on the connections between them. You can use OBJECTiVE's assembly tools quite effectively to temporarily reorientate assemblies for modelling purposes and then return them to their original position.
2010-11-15 09:35 PM
2010-11-16 09:35 AM
NStocks wrote:The split line must at least touch some part of the object to be split. In the case where you have a huge void between the bodies in a single object, make the cut so it takes a tiny sliver off on or other body.
How can I split this elevation profile again so that they become 2 separate pieces? I've split the original profile already on the top, but it's created to outer edges to still be joined together...
