Mats_Knutsson
Mentor
Howto - spiral stair with center column?
Like any Weland fire escape stair for example...
How do we do it with 21?
Mats
AC 25 SWE Full
3 Replies 3
Dontknow
I once made a spiral stair out off morphs with a handrail (spiral) from the library.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
I just watched an interesting video by Eric Bobrow the other day where he made a custom spiral staircase.
https://www.youtube.com/watch?v=IRttsLcWtD8
Using non-custom components will be a bit easier.
It really is as easy as getting the settings you want then placing a stair using one of the arc options in the pet palette.
A couple of clicks and I had this (no centre post - that is just a column).
I also just found this.
https://helpcenter.graphisoft.com/tips/archicad/modelling/stair-tool-basics-spiral-stair/
