Luis alberto
I can't use the pipes in mep, why.......
What can I do, please help.
2 Replies 2
CosminF
you can try going to options - project preferences - route preferences and either:
1. reimport your tables from a different project
2. create new ones and use those.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Karel Landa
This will probably be connected to updating Archicad.
I think that in Update 1 of AC28 there was added a possibiltity to set preferences also for reductions.
Go to the settings of pipes to the reduction part and in lower part select one of predefined. (I'm currently using CZE so "CHYBĚJÍCÍ" means "MISSING" 😉 )
From Archicad 17
MacBook Pro M1 Max
