ā2014-12-09 08:15 PM
ā2014-12-12 12:36 AM
Tom wrote:You should use an Optical Character Recognition software to convert the image texts to real texts, then saves as PDF, then import into ArchiCAD and explode.
Explode the PDF? Didn't know that was an option. I tried it with the explode into current view command but it didn't work. This PDF was created by a scan, rather than exported out into a PDF format. That may be the problem.....any thoughts on that?
Thanks
ā2014-12-12 04:59 AM
ā2014-12-12 07:21 PM
ā2014-12-12 07:25 PM
ā2014-12-13 02:11 AM
ā2014-12-13 03:50 AM
Rogerdodge wrote:Discussed earlier in the thread...
Can you not convert or save the Doc file as pdf, then import into AC & explode?
ā2014-12-13 05:29 AM
