Tom Krowka
Import .TXT or .DOC file into AC
Is there any way to import .doc or .txt file into AC so the text in the original file comes in to the program as text. The original file has lots of text boxes within which the real text resides. Cut and paste would not be practical as there is a lot of text. I could practically retype it quicker.
Can't seem to find a way to do that. Seems simple....
Thanks Tom
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
16 Replies 16
Erika Epstein
Tom,
Try copy & paste.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Tom Krowka
Original text is in text boxes. There must be 1000 text boxes. Have to open each text box in the orginal, copy, then go to AC, do a text command, then paste. Don't want to do that 1000 times. Looking for the import the whole file method.
[email protected]
www.walshkrowka.com
Erich
You could try printing the documents as PDFs then importing and exploding the PDF file in ArchiCAD.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Erika Epstein
Sorry Tom, misread your original post.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Tom Krowka
Explode the PDF? Didn't know that was an option. I tried it with the explode into current view command but it didn't work. This PDF was created by a scan, rather than exported out into a PDF format. That may be the problem.....any thoughts on that?
Thanks
[email protected]
www.walshkrowka.com
Erika Epstein
Start typing
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Tom Krowka
Bummer. But thanks anyway as I didn't know that was one of the new features. I guess I need the original PDF not the scanned copy.
[email protected]
www.walshkrowka.com
Erich
I thought you said it was a .doc or a .txt file. If you are working from a scan you are out of luck with the explode pdf option. It's a cool feature when it works though.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
Tom Krowka
I have the file in three formats. None of which I can import directly. Multiple bummers.
[email protected]
www.walshkrowka.com
