2015-10-25 01:14 PM - last edited on 2023-05-24 07:26 PM by Rubia Torres
2015-10-26 04:40 PM
2015-10-26 05:25 PM
laszlonagy wrote:I am importing 200 furniture details. It is impossible to convert them all separately to morph,and then again to GDL. In ArchiCAD 18 the same file is rendered correctly. Maybe in future updates this will be corrected?
You can select the Morph and use the File\Libraries and Objects\Save Selection As\Object to re-save it as Object. Then you will again have the correct solid geometry in a GDL Object form.
2015-10-26 05:40 PM
2015-10-26 10:07 PM
laszlonagy wrote:Yes,shure. I,ll post the scene.
I see.
Could you ZIP and post 1or 2 of these objects as attachments? Hope they are not very large object so the forum will allow them to be uploaded.
If this is an OpenGL error then the developers might be interested in knowing about it. OpenGL has been rewritten for ARCHICAD 19, so this may be an issue arising from that.
2015-10-26 11:48 PM
2015-10-27 06:29 AM
2015-11-23 02:57 PM
2015-12-17 08:17 AM
2016-10-03 07:44 PM
