Inserting a big image in Archicad 10 is not visible
If I try to inserting a big image (40MB jpg or 125 MB tif) in Archicad 10 is not visible how can I resolve the problem
If I try the same in Archicad 9 all its OK.
I work currently in Archicad 10
11 Replies 11
Djordje
Which computer? Which OS?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
xp pro sp2, intel extreme edition dual core 3.7, 4gb ram, 512 mb video mem
Try to same a lower resolution version (say half its size) of the image to see if that works.
If that works it probably means that the original image size is too large for AC to handle.
Link
According to GS literature for ArchiCAD 10:
Handling of bitmap files has been enhanced. In previous versions,
the size of bitmap images was limited to 4048x4048 pixels. The
limit has now been raised significantly (to 32767x32767 pixel size)
in all these areas:
- When importing/placing bitmap images with the Figure Tool.
- When setting Rendering Size
- When setting Rendering Background Size
- When Printing/Plotting bitmaps.
Link.
Djordje
Check the image roatation problem as described on the Wiki
http://www.archicadwiki.com/Bugs/Drawings_with_images_do_not_print
Djordje
HP Omen
in all these areas:
Link.
Sorry Link, I meant the file size not the image size.
Link
Are there any details on filesize limitations Laszlo?
Link.
Aaron Bourgoin
Not visible to print? see: http://www.archicadwiki.com/Bugs/Drawings_with_images_do_not_print
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.0 USA
Rhino 8.32 Mac
MacOS Tahoe 26.5.1
Link.
I don't know of any. Only the image size limitations mentioned earlier.
