Invisible Disappearing Doors
I was working on a plan one afternoon and next thing i know all of my doors had disappeared. The opening remains and i can select the door but i can't see it.
I don't remember modifying anything.
It just seemed to have happened.
25 Replies 25
Archibot wrote:
It is unclear what version of the update i should downlowd from the table on the link you provided. help me out
This will provide all of the updates to 8.1 R2C, no matter what patch you are currently using...
http://www.graphisoft.com/support/archicad/downloads/USA81.html
You will also want to get the updated library as well....
http://www.graphisoft.com/support/archicad/downloads/library_updates/usa.html
Before you update...read this...
well i updated to ac v2 and nothing has changed.
Djordje
Which library? Standard one or something else?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
It should be the standard library too. I have never changed it. and i just updated to the new library.
I realize now that it's not just the doors but all of the objects within that particular tool [door, windows, openings, corner windows].
all of them are invisible yet selectable and able to be modified.
all of them show up in 3d view and when rendered but not in 2d plan view.
Ben Cohen
Check you display options. right click on plan/display options. Here in "doors and windows" you have the option to hide on plan
Hope this helps
Ben Cohen
Mac and PC
Archicad (Latest Version) aus
www.4DLibrary.com.au
Hope this helps
YOU ARE THE MAN!!!! IT WORKED. I DONT KNOW HOW IT GOT CHANGED BUT THAT FIXED IT!!!!!
YOU ARE MY NUMBER ONE!
THAKNS MAN
Ben Cohen
Glad to help someone else out finally!!! Score is Ben - 1 Architalk - 1000
Ben Cohen
Mac and PC
Djordje
Lose the sugar ... double espresso is fine 😉
Djordje
HP Omen
Ben Odonnell
Archibot wrote:
Hope this helps
THAKNS MAN
One more thing to add here. It's probably defined in one of your view sets. So if you select that view set again the same thing will happen. What you will need to do is to redefine you view set so the doors and windows remain visible on your paln.
HTH.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
