Is there a way to include columns in the border as well?
LeeJaeYoung
Press the spacebar to search the area and the pillars will fall out
If not, "No." I would appreciate it if you could say it coolly.
What is the criteria for finding a magic wand?
AC27 on window 11
1 REPLY 1
sayon3d
Hi Lee,
no there isn´t. The magic wand highlights one element at the time.
What I do is,...group all the same elements. One group: all the same columns, Other group: all the same slabs, etc...
This way you can change all elements at once in the group that you select.
Hope this helps you further.
