Is there a way to turn off the XYZ symbol in the 3D window?
Eric Bobrow
[APOLOGIES FOR DOUBLE-POSTING - I originally posted this in the Schedules forum section by accident]
I checked under View menu > Onscreen View Options, Grid Display, Editing Plane Display, and 3D Window Options, and also the Options menu > Work Environment > Onscreen Options, and couldn't see a way to turn off the XYZ indicator in the 3D window.
As I recall, in the GDL editing environment, there is a little icon button in the lower-left navigation area that turns this off and on, but I don't see this in the 3D Window navigation area.
Does anyone know if it is possible to turn this off?
Eric
1 REPLY 1
David Collins
It dissappears in 3d Explore mode, if that's of any help.
I confess it's never bothered me that much, but it certainly could be a little less obtrusive and a visibility toggle would be nice to have.
David Collins
Win10 64bit Intel i7 6700 3.40 Ghz, 32 Gb RAM, GeForce RTX 3070
AC 27.0 (4001 INT FULL)
