2017-07-15 01:46 PM - last edited on 2023-05-26 12:18 PM by Rubia Torres
2017-07-15 07:06 PM
2017-07-15 10:08 PM
James wrote:Yes, thank you; I figured that out;)
To turn off windows in the 3D use the Filter Elements in 3D dialogue, available from the context menu of the 3D window tab, or I think you can also use MVO to hide windows.
2017-07-15 10:18 PM
famadorian wrote:Are the Slabs correctly assigned as Load Bearing? And are the Slabs composites with at least one skin defined as Core?
Also, it's not showing slabs. Are slabs not part of load bearing elements?
2017-07-15 10:22 PM
James wrote:You're right;) Somehow it was not defined as core;) Thanks.famadorian wrote:Are the Slabs correctly assigned as Load Bearing? And are the Slabs composites with at least one skin defined as Core?
2017-07-15 10:53 PM
famadorian wrote:You’re welcome, glad you got it worked out.
