Kiarara
Log house joints
Hello!
I am working with log houses and I need to find a way to model correct joints to log walls (for example dovetail joint as show on the picture). How can I achieve this?dovetail joint.jpg
Setup info provided by author
1 Solution
CosminF
depending on how accurate/specific you want the log wall intersection to be you can:
1. use the log wall option - directly from the wall settings. On one wall you can start with a full wall and the next one start with half log.
https://helpcenter.graphisoft.com/user-guide/88530/
2. model the wall out of curtain wall (in this way you can have different profiles on the ends (where the intersection is) while still being able to have openings and even schedule each independent component
3. Use morph or segmented beam to define the geometry of the intersection and make just the corner joint a different element that aligns with a log wall made as per 1st point.
https://community.graphisoft.com/t5/Modeling/Beam-Segments-Tips-and-Tricks/ta-p/303944
4. If you work often with this type of construction maybe a third party addon could prove useful:
I found this in a quick google search:
https://www.graphisoft.com/partner-solutions/archiframe/
hope this helps.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Go to post
2 Replies 2
CosminF
hope this helps.
Kiarara
Thank you very much! 😊
