Lost material
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2011-03-26 01:06 AM
I have tried repairing the installation from the disc but that didn't work - I don't want to do full re-install in case I forget to save some of the personalising I've done. (I only use the program, I don't know where everything is stored & how to replace it.)
Perhaps someone could give me the settings for this to save me experimenting with the large number of parameters to try & re-create it?
Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-03-26 01:09 AM
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-03-26 01:22 AM
It shows up as " ? MISSING" in the materials (I noticed that it wasn't rendering as I expected & checked).
Won't that be the case for all files?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-03-26 01:37 AM
The only way that a material should go missing is if you have deleted it from the material list, if so you can get it back as previously suggested.
If that material has a texture and you have deleted it from your texture folder then that is different.
In the US version there is no Glass-Mirror material.
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-03-26 01:35 PM
If the material was part of the original installation (in other words, not one you created or imported), you can do a New & Reset, which will open a blank file with the original materials. You can assign this material to an element (like a Slab) and copy then paste it into your current project, the material will be added to your project file.
David
www.davidmaudlin.com
Digital Architecture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-03-26 04:33 PM
As the others are saying, you can recover the material either with attribute manger or by copy/pasting and element from another project. An advantage of attribute manager is that you can see, and have some control over, the index number. With the copy/paste (or merge) the new materials will be indexed to the next numbers available.
You don't say where you are getting this "missing" alert. In library parts it can happen that a materia will come up missing even if you have a material of the correct name but with a different index number.
This can be a bit complicated and since I don't know the details I'll leave it at that for now. HTH.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-03-26 10:00 PM
And if you don't have a good backup system, this would be a good time to start one!
Shoegnome Architects
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-03-26 11:13 PM
I have resolved the problem (using Attribute Manager, as suggested).
I have no idea how I managed to delete the material
I was wary of opening other files before I had a solution that would work in case the problem was going to repeat itself.
