MERGE TWO FILLS
Llian
There must be a way...likely I forgot..how do you merge two fills into one?
Lilian Seow
LEED AP | cSBA | CAPM | PMP
Interior-Architecture and BIM Management
AC20 USA | 27- macOS 10.14.6| 4 GHz Intel Core i7| 32 GB RAM | Archicad-user since 1994!
6 REPLIES 6
RandyC
pet pallet - add to polygon - look for a + sign --
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
Llian
Thanks Randy. I am aware of adding [+] to the polygon but I am thinking if I can select two intesecting polygon and merge them.....
Lilian Seow
Eduardo Rolon
Edit->Reshape->Fill Consolidation
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Llian
WOW......Thanks so much!
Lilian Seow
Good day.
Whenever I try to merge two fills with the Fill Consolidation tool, whether from the toolbar, keyboard shortcut or edit menu, nothing happens.
If I'm not mistaken a wizard window is supposed to pop up that lets you tick boxes of every Line Consolidation option that you wish to execute.
The fills I'm trying to consolidate are identical and I've made sure that they don't have transparent backgrounds.
What am I doing wrong?
Regards Z.
It is working for me.
