2025-08-11 05:10 AM
I have set the project orientation graphically to 191 degrees. What is the correct way to make all fills automatically match this orientation?
Operating system used: Windows 10
		2025-08-11
		08:29 AM
		2025-08-11
		12:47 PM
As far as I know (and I just checked), it is not possible yet to re-orient all the fills at once. You will have to reorient them one by one or do a bigger one and split it into multiple smaller ones (in your case, the rooms).
Similar question to yours:
https://community.graphisoft.com/t5/Libraries-objects/How-to-align-fills-according-to-graphic-orient...
A workaround for this would be to reorient the fill in its settings and it will override everywhere. But you need to do this for all fills that you are using and use the value to offset your 191 degrees rotation.
hope this helps.
2025-08-11 11:05 AM
Curious to for the reason to work at a such an angle.
