Material not applied to Wall
If I apply material texture to my wall surface it doesn't it I'm using archicad 22 pls any idea
2 Replies 2
Lingwisyer
Guru
Can you post a screenshot of the problem?
Check your MVO settings?
Ling.
How are you 'applying' the material texture?
You may also have a Graphic Override or Renovation Filter in place that is overriding the surface material, so no matter what you change it to it will look the same.
