Bruce
Measuring problems in Teamwork
I've inherited a file from someone (externally) who has turned all the elevations & sections into drawings. Problem is they're inaccurate and I need to update them with correct window sizes etc.
However, I'm in a teamwork file and someone else is working on the plans and I'm on the elevations. How do I measure the size and location of a window if I can't use the line tool to measure with (i.e. I'm locked out of the plan space)? A measure tool would really be useful right about now.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
38 Replies 38
s2art wrote:
I know it's not what you want, Bruce, but even using a marquee you can read the co-ordinates. it does pick a point perpendicular to your starting point too, just not sure if it will work in Teamwork area assigned to someone else.
Cheers
Actually this is a great tip. Because you can set the marquee to draw a polygon outline you can then measure in any view. Thanks Stuart!
Bruce
Although I appreciate all of your replies (and I do - apologies Tom if I sound like I'm attacking anyone) - my frustration still remains.
I won't go on as I will just be repeating what I've said earlier - which I still think is pertinent.
Once again, I very much appreciate your replies (and I mean that).
Cheers.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Bruce wrote:
....my frustration still remains.
Cheers.
Did you try Stuart's marquee tip? Works very well! I would suggest putting it in the tips topics.
Bruce
Sigh.
Yes, everything suggested in this thread is a good 'tip'. They have helped me and I think it's all valuable knowledge. I will use these techniques now that I know of them.
The point I'm valiantly (and it seems futilely) trying to make is that there shouldn't be a need to get 'tips' when it comes to measuring something. Anyway, I don't want to step on anyone's toes, so I think I'll refrain from trying to emphasise my point further. I could even be wrong
Many thanks.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
I do agree with you, Bruce. There should be a measure tool, just because there should be.
I think the tool most often used is the fabulous, yet sometimes hard to find "work-around" tool, which I couldn't do without. Maybe it should have its own pallette?
Rakela Raul
in version 5 or 6 when i first looked at ac that was my first question to the reseller, dont u have a measuring tool??...now, i dont care about that tool
anymore,,, i would rather much better have a footing tool instead
(a good example of a measuring tool is found in microstation..btw)
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
Hi guys,
I'm not sure if this is obvious or obscure (maybe both!), but you don't have to use a tool to measure something. Place the user origin at one point (alt-shift) and then hover over the other point. Read the coordinates (whichever you need) and that's your distance. I guess one advantage to this method is that you can use it mid-command (i.e.: while in another tool).
This is the way I've always done it and recommend to our users. Of course this won't work along an arc...
Link
That was back one page one mate!
Link.
Ah-ha! I read this whole thread and I guess I missed it. Of course, now that you pointed it out I see it. See...obvious AND obscure!
Petros Ioannou
Bruce
another way to find this non-existing perpendicular line on your example
is to select the left wall and (having the arrow tool active), ctrl-click on the node of the other wall. This will create a hotspot on the projection of this node on the wall. So you can measure this distance having two nodes.
I am not sure if this can help since you work on Teamwork.
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
